535d Motorschaden - Motor fest
  • Engine not need to get out, but yes oil pan must be removed. Some mechanic recomend that bearings are replaced, so I asked. The car has no problems, but timing chaing at this km...
  • You can either decide of removing the transmission or the engine to do the timing chain. It's about the same amount of work.
    So if you want to inspect the bearings you should go with the engine removal.
  • Maybe someone has an answer for me. When changing conrod bearings for my 550d found out that Kolbenschmidt set for N57D30C fits all diesel engines for F series. However, the OEM part catalog says conrod bearings are interchangeable only between 1.6-2.5 diesels in F series and m50d. OEM was Schmiedmann if I'm correct. So got a bit confused why 3.0 and 3.5 diesels are not listed there.
    Has someone used Kolbenschmidt set on 550d without any issues?
