Bimmercode CAF [JBBFE] => 3000 Wipe_Wash
  • Good afternoon,
    I'm trying to code the headlight washer so it doesn't activate above 5 km/h. It defaults to 160 km/h. The speed limit of 5 km/h is supposed to be activated during the MOT, but not while driving, since it tends to dirty the windshield more than anything else while driving... and the headlight washer caps don't fit particularly well anymore... Also, when it rains, I usually stop every so often and clean the headlights if they're really dirty and can't be seen well...
    I've seen that in Bimmercode (for the F10), you have to do it in the passenger compartment, specifically:
    And in expert mode, go to:
    SRA_GESCHWINDIGKEITS_DEAKTIVIERUNG and set werte to 05
    However, that value doesn't allow you to set it, as it only shows 00 (not active), 01, 02, 03, and 04, which I understand are the values that appear in
    IGR_SPEED_THRESHOLD
    160 km/h 0xA0 01
    120KM/H 0x78 02
    140KM/H 0X8C 03
    180KM/H 0XB4 04
    I've tried adding a custom value here in IGR_SPEED_THRESHOLD with 0x05 (5km/h) and 0x0A (10km/h) and it works, but then in
    SRA_GESCHWINDIGKEITS_DEAKTIVIERUNG it still won't let me enter values other than the old 00 (not active), 01, 02, 03, and 04......
    Does anyone know how to do this?
    Thanks and best regards
  • Write in english or use translator.
  • feralejav
    Hat den Titel des Themas von „Bimmercode CAF [JBBFE] => 3000 Limpiador de toallitas“ zu „Bimmercode CAF [JBBFE] => 3000 Wipe_Wash“ geändert.
  • Not possible as you like.
    Only possible to set SRA off (SCHEINWERFERREINIGUNG nicht_aktiv) or increase the operations (ANZAHL_WASCHBET_ZUR_SRA up to 10 and the impulse (ANZAHL_SPRITZIMPULSE) down to 2.
