Hello. I have an F11 528i xDrive and have a problem with the steering. It's getting hard to turn the wheels when appear. What can it be?
Altered steering response
Power Steering Servo Fluid checked ? Any foaming ?
Exact codes using ISTA would also help.
It's an electronic power steering so it's not have fluids. I found this error 4823ff
That fault code means OC (open circuit). Please check the ground wire from the electric steering motor. Should be a brown cable.
